Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 1515 Ver todo
battery percentage dropping, from 50 to 1
Hi all,
Quick question :
i have an iphone 6s.
battery is sometimes going from 60 or 50 procent to 1 procent.. the 1 procent can bee for several hours..
sometimes i don't have this problem .. strange..
I measured out the battery and that was good. I checked the life of the battery and still above the 90 procent , ( what i figured after the measurement)
what could it be? the IOS 10- 11 "bug" draining the battery or giving faults ?
TIGRIS or TRISTAR?? could that be a possibility ?
what would i do? : hard rest to reset the battery?
Thanks in advance
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I think you are on the right track with thinking U2. Check the charging circuit to see if you are experiencing :Ghost charging" (Fake charging)
Fue útil esta respuesta?
Calificación 2
Comentarios:
Hi,
Now i did a hard reset ( + a software update to IOS 11.2.1 ) and fully charged the phone, i'm trying him out.. and he is working ( discharging) fine... so far..
but : if i check the amperage when charging i see the amperage going from 0.33 tot 1.2 ( continously between those amperages.. ) ...
por
I will try to drain the battery now and charge him again..
por
battery was empty, the discharging was normal. when i plugged the phone in to charge : it started to charge but the amperage range was between 0.33 and 1.06 amp. after a minute of 3 the amperage was continiously on 0.93 amp.. the fluctuating amperage is not normal i think... and it's not all the time...
any suggestions ?
por
Here's a good thing to check. Make sure to check and see if your iPhone 6s is affected by the battery recall, because that symptom matches completely to the recall. I've attached a link where you can punch in your SN and see. Also, if not affected I recommend downloading coconutBattery and seeing what it says about the number of loadcycles and life remaining. Let me know what happens!
6s Recall Check
Calificación 0
Comentarios:
Hi Ryan
The phone is not in the range of te "broken" phone's...
I checked the loadcycles ( 256) an life is on 90 procent...
strange ...
por
Añadir tu respuesta
Kevin D estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 14
Últimos 7 Días: 69
Últimos 30 Días: 254
Todo El Tiempo: 1,046
