Guías y soporte para varias marcas y estilos de TV.
Preguntas 3454 Ver todo
How do you hook up Bluetooth headphones to a Samsung smart tv?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 10
Comentarios:
John Grossman what model is your TV?
por
Hi John Grossman,
What is the model number of your TV?
Have you verified that your model TV does have the BT feature?
por
Mine is UN50KU6500 and i cant get it to recognise my bluetooth earphones (they are not samsung).
por
samsung un46d6003
por
@Danriv ,according to the specs, the samsung un46d6003 sf does not have Bluetooth from what I can see and I did not see anything about Bluetooth in the manual either.
por
Mostrar 13 comentarios más
Agregar un comentario
2 Respuestas
Solución Elegida
First and foremost thing you need to hook up your Bluetooth headphone is to check as if your TV is Bluetooth enabled TV or not. If it is Bluetooth TV, you can simply pair it to connect the Bluetooth and can enjoy the music in your headphone. Otherwise, you can use Bluetooth transmitter to connect to the TV. For connecting Bluetooth Transmitter , you can check the link:
http://transmitterreviews.com/how-blueto...
Fue útil esta respuesta?
Calificación 6
Comentarios:
thanks - all set
por
Press the Home button on your Samsung Smart Control, to access the Home Screen.
Using the directional pad on your remote, navigate to and select Settings.
Select Sound Output to select your preferred sound output device.
Select Bluetooth Audio to begin pairing your Bluetooth audio device.
Calificación 1
Comentarios:
I have done this but there is no Bluetooth option found. There is no home button on my remote .
por
what is the model number of your tv?
por
Añadir tu respuesta
123fake estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 594
Últimos 7 Días: 2,752
Últimos 30 Días: 14,438
Todo El Tiempo: 87,493
