Power On No display
Its Power on but gives display sometimes and sometimes not give display
Es esta una buena pregunta?
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
Fue útil esta respuesta?
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 691
1 comentario
maybe a loose cable
- de daniel
