Why does my dryer keep blowing thermal fuses.
Dryer heater won't cycle on and off. Vents are clear because I can feel cold air from outside when dryer is off. I've also inspected ducts. Can a damaged blower wheel cause the cycling thermostat to fail or the thermal fuse to blow? Or both?
Es esta una buena pregunta?
14 comentarios
If the heating element is not glowing evenly could that cause the high limit thermostat to trip before the temperature control thermostat?
- de Random Brandon
Okay. Recently on an Amana dryer these were the parts that were changed out or repaired or replaced and, each time the dryer comes on I put it on different Cycles like for instance I put it on timed drying and I started out at the highest timed drying which is Heavy Duty 70 + No Heat (Air Fluff) seem like throughout each cycle there's no heat the coils in the back of the dryer heat shaft is not getting hot; however, it only spins and there's cold air blowing out, and everything seems to be hooked up properly but, I can't get any heat from the element and it will not burn. So, possibly there's a multitude of other problems and other conclusions why it's not allowing power to get to the element.
- de littlemac30
Tengo una secadora marca General Electric,que corta el secadomuy frecuente y no calien.me ta lo suficientemente me podran ayudar?
- de ruben serano
Okay, same problem here. Replaced the thermostat 2 times, the thermoster, and the heating coil, good airflow. Drum apins, Dryer will dry about 3 loads then stop heating works otherwise, just won't heat. Does throw any codes. Any thoughts? HELP!
- de Scott Priester
Doesn't throw any codes
- de Scott Priester
Mostrar 9 comentarios más
