Saltar al contenido principal
Información y guías de reparación del iPhone 8 que salió a la venta el 22 de septiembre de 2017. Modelo: A1863, A1905
Preguntas 856 Ver todo
Can you use the internal battery of an iPhone 7 inside an iPhone 8?
I’m guessing because of the similar sizes of the phones, the battery from the 7 can be used for the 8. Is it possible and has anyone tried it? I ask this because it seems that the iPhone 7 has more mAh in its battery and this could make your 8’s battery life even better. Just curious lol
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
So I did some research on the internet and discovered that they appear to be physically the same size. So if the question is will it fit in the casing, then Yes it can. However, you asked can you use the battery in an iphone 8, which, from what I can tell, the answer to that question is no. First, the connector is completely different. You can see this here: https://d3nevzfk7ii3be.cloudfront.net/ig.... and here: https://d3nevzfk7ii3be.cloudfront.net/ig.... If for some odd reason you found some sort of "adapter", the Watt Hours and the Voltage of each battery are different, which I can imagine the iphone would have a problem with. In conclusion, (Or to save you the reading and research. ;) ) The answer is no.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Syam Angalakuditi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 21
Todo El Tiempo: 1,398
