iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 411 Ver todo
No backlight no display
Hi,
I replaced a screen on an SE, and not the phone does not display anything. Backlight stays off, and shining a light on it reveals nothing. The phone does turn on and it does vibrate when you switch the silencer.
Tried disconnecting the battery and holding the power button, no dice. Tried multiple screens that work, again no results. This sounds like a board issue. What do you think it could be? Backlight coil? Fuse? Some other chip?
Thank you
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Are you using original 5s screen, aftermarket 5s screen or original SE screen / aftermarket SE screen?
AFAIK, some aftermarket 5s screens will work fine, original and aftermarket SE screens on the iPhone SE.
Fue útil esta respuesta?
Calificación 1
Comentarios:
I'm using refurbished 5s screens from original 5s screens. Havent had a problem with them. With aftermarket it was hit or miss. Screens arent the issue, but thanks for your input
por
Añadir tu respuesta
Den R estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 55
Todo El Tiempo: 230
