Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Connector will not go back on
In disconnecting the digitizer cable connector, in trying to replace the front panel on my iPhone 5s, I accidentally unconnected a small rectangular connector next to the battery (not the LCD or front facing camera, they were already off.) Now it won't go back on, Is there a trick to it?
Es esta una buena pregunta?
Puntuación 0
1 comentario
I took it to my local smartphone/tablet/computer repair. The guy at the front desk got out his splunger and had it back on in about a 30 secs. He did some other stuff for me. No charge! ITech Smartphone Repair in St Augustine, FL. Highly recommended!
- de
Agregar un comentario
2 Respuestas
Solución Elegida
See the comments. I found a guy who fixed it.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
it looks like its broken and the connector above doesnt seem to be in good condition either
Puntuación 2
2 comentarios:
is it possible that the connector attached to the board got separated from the board and came up with the connector at the end of the cable?
- de
It's all possible. That connector has seen better days. If some of the pins lifted from the logic board, then you won't have a good electrical connection.
Try to inspect it under magnification to see. You might be able to re-shape it (be very gentle). If the connector has physically been damaged or is no longer connected, a micro-solderer can replace the connector.
- de
Añadir tu respuesta
William Kolb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 60
