El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3639 Ver todo
Lost “setting, battery usage” after battery replacement. All else grea
Replaced battery. Reset phone. Discharged to zero multiple times over 2 months. Battery usage just states “battery uage will be available after a few minutes ”
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hey there! iFixit employee here. I just tested several batteries in benches, and I haven't seen any issues with showing usage. If you haven't already, hold the power and home buttons to do a full reset, and see if that solves the issue. If you don't have any luck with that, you may actually have some minor logic board damage.
Hope this helps, and remember not to take everything an Apple Tech will tell you at face value. Happy repairing!
Fue útil esta respuesta?
Calificación 1
Comentarios:
Thanks for the info. I will try the reset again. It is good to know that the battery should work properly.
por
Did you remember to make sure iOS is updated to the latest version? If not, check for iOS updates. (settings>general>software update)
Calificación 0
Comentarios:
Yes, I have been sure to update IOS. Just for the security updates if nothing else. The replacement battery was branded as "ifixit" and purchased at Fry's Electronics. The Apple store tech says that there is a chip in the apple battery that is not in the aftermarket. I have no idea if this is true. It is very puzzling that everthing works except the battery use indications. That is why I posted my question here.
por
hold on. I'll answer your question once I get a answer from iFixit's product inquires
por
Añadir tu respuesta
Michael Kostyra estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 28
Todo El Tiempo: 210
