Why won't my charger work
Every time I try to charge to I have to shove the charger in and push up cause its refusing to charge.
Es esta una buena pregunta?
Try a different charger cable, if that fails, try a different USB block, if that fails, try a different outlet or computer that is powered on.
OK then. So you can order a new charging port assembly here: https://www.amazon.com/Highfine-Charger-...
And then follow this guide: Asus ZenFone 2 Motherboard Replacement up to step 8.
Good luck!
Fue útil esta respuesta?
Its not the charger its the phone plug in the middle a metal piece is shoved upwards and i cant get it to be in the right spot for my phone to charge
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 947
