Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
Preguntas 97 Ver todo
Replaced battery but iPod still doesn't charge
I recently replaced the battery in my 3rd Generation iPod (A1040 20GB). It briefly powered up, worked and played music but the battery was low on charge and it quickly died. However, when I connected it to a wall charger it wouldn't charge. I have the same result when I connect it USB to a computer. I've tried several different kinds of wall chargers with the same results. When I plug it in it will briefly flash the Apple logo then go to a battery icon with a triangle with an exclamation point in it. I appreciate any help.
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Have you tried replacing the charging port?
Fue útil esta respuesta?
Calificación 0
Comentarios:
I have not. I'll explore that option, thanks for your response.
por
You can either try a MB with the charge port already on it or a new charge port by soldering. But that's the next step. It's been hard finding main boards for these these days though
Calificación 0
Comentarios:
By "MB" are you referring to the logic board? (IF192-001-1).
por
Yes that's what I meant . MB short had for main board
por
Añadir tu respuesta
Brian Martin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 52
