Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2686 Ver todo
iPhone 6s Ghost Phantom Touches after Refurb
Recently repaired an iPhone 6s with damaged LCD and bent chassis housing.
Replaced both and it’s now back with Phantom/ghost touching, slow glitches.
I am wondering seeing as the Touch ic On he 6s is attached to the rear of the screen is that where my trouble lies or could it be anything to do with the replacement housing?
All screws and brackets are properly in place it’s just odd as my replacement lcds on the 6s have never really had much trouble.
Thanks
Update (11/22/2017)
UPDATE: A new screen doesn't solve issue and the screen I took off seems fine on another device. Now this may seem strange its also quite slow and sluggish at times and ive noticed this is all fine if the device is on the charger?
Any ideas guys?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Have you tried another screen yet?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
SOLVED:
The new housing want the greatest fit and was putting too much pressure on the lcd which in turn was causing all sorts of touch issues.
Seems to be working fine in a different original Housing.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Certainly try another screen. But with a bent housing, the logic board may have been damaged as well. It could look fine but some copper traces or soldered connections could be damaged. Because the Touch related IC's are on the screen, the damage could be in the digitizer connector area.
Puntuación 1
5 comentarios:
Any ideas guys?
- de
What version of iOS are you on?
- de
Currently running on 11.1
- de
Going to 11.1.2 now
- de
Same issues. Could it be a power issue?
- de
Añadir tu respuesta
Niall estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,812
