Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1525 Ver todo
Help on iPhone 6 plus long screw damage
Hello,
I recently ordered an iPhone 6 plus that I wanted to learn a bit of board repair on and sell it on as I usually do however I was hoping that this would only be a backlight filter replacement. I replaced the filters that needed replacing and the phone still has completely no backlight but you see the image when you put a torch to it. I have noticed there is long screw damage in the holes and I have got a diagram where the traces are.
Can anyone lead me through this repair as I'm unsure if I'm doing this correctly and I have also ordered some 0.1mm jumper wire that I think will be good for the traces. I have some pictures of the bottom right hole that I have tried to pick the layer off of but I don't see what is wrong with it. Can anyone please help me with this, I would be very grateful
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Other than the Filters, Have you checked shorts on Caps? and/or replaced the 2 Diodes, Coils and Driver IC's? Check D1501, D1589, L1503, L1589, U1502, U1580. If so, and they are good...and you still believe it is long screw damage, use a multimeter in continuity mode (With beep) to check the traces for breaks by probing one end of the trace to the other in exposed areas.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
I have checked the caps with continuity mode and there is no beep. I have had a look at the traces and there are 3 that are broken. I will highlight the broken traces on the picture of the traces
- de
I would just add a dab of flux, tin the traces and the jumper wire and add 3 jumpers. test it and if working, add a bit of solder mask over the opened area. It is really hard to see the traces in the pictures, but if you have verified they are broken, then Yes, definitely add the jumpers
- de
Thank you very much, I will keep you updated when I get around to doing that
- de
Añadir tu respuesta
Tom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,474
