Saltar al contenido principal
Guías de reparación y soporte para teléfonos fabricados por Lenovo.
Preguntas 283 Ver todo
Half touch screen is not working? Lenovo Phab 2 Plus
I dropped my Lenovo Phab 2 plus a few days ago. It looks completly fine. No broken screen or touch. Still, half touch is not working. What should I do?
How to fix it?
Should I change my touch screen or complete glass and touch screen?
Thank you in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Whatever the issue is, you need to disassemble it to inspect it.
Here is a video.
https://www.youtube.com/watch?v=IAVdR2By...
1) check for loose cable. If it is loose, make sure it is firmly attatched then reassemble
2) If the screen is at fault, replace the whole assembly.
http://my.ebay.com/ws/eBayISAPI.dll?MyEb...
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Given the symptom, what is the most likely problem area?
- de
Given that it was dropped its either of the 2 things that I mentioned, either a cable came loose, or internal hidden crack on the digitizer. The display is a single piece so replacing the whole assemble is easier than just replacing the digitizer.
- de
Añadir tu respuesta
Akash Rupareliya estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 5,545
