HTC Desier 816 : Not Turning on
this htc shut down suddenly and never turn on again , i 've searched for the service manual or datasheet or schematics but i didnt find anything , the battery seems dead the voltage drop on its pins is 0.8 volt when i put the charger it still 0.8 , removed the battery and measured the voltage drop between mobile battery socket pins while connecting the charger and the voltage drop was 0 , i tried to turn it on using my power supply when i press on power button it start consuming current 0.13 amp and keep like that if i let it connected to the power supply with no turning on , so i think the problem is on charging IC , what do you think , and what do you advice me to do
Es esta una buena pregunta?
