The Xbox One X (Model 1787) is Microsoft's latest high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
Preguntas 21 Ver todo
Xbox One X internal SSD upgrade possible? (cloning to 1tb ssd)
I upgraded my xbox one internal hdd to 1tb ssd by cloning, now since the xbox one x is out and uses sata 3.
Im hoping you guys got the teardown and possible news for hdd replacement :)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
6 Respuestas
Respuesta Más Útil
Take a look a YouTube video from XFiX on how to create the XBOX ONE HDD (SSD).
There are two methods for Linux USB and for Windows.
Xbox One S and Xbox One X HDDs have the same structure.
I used this method for 2TB Samsung EVO SSD (MZ-75E2T0BW).
I created the Xbox One SSD (four partitions) in Windows 10, copy/pasted all files from the original drive into my SSD (System Support, System Update, Temp Content and User Content), replaced the drive in my Xbox One X (not Project Scorpio) and it is working just GREAT!
For HDD replacement just follow the Xbox One X teardown video here on ifixit.
14 screws T10 and 2 screws T9 (USB connector). No other tools are required.
Fue útil esta respuesta?
Calificación 5
Comentarios:
@taurus330 how much of a performance increase did changing the internal HDD to a SSD did i make?
im thinking about doing the same and im wondering if its worth buying a 1tb SSD to do it
por
SSD has at least 30% performance increase at console bootup.
Some games like Fallout 4 have 50% less loading time.
In WOT I have to wait 10-15 sec until other users will complete the load to join the game.
I didn’t measure exactly but it’s something really “visible”.
From other side, SSD has no vibration, less heating and noiseless.
2Tb is better than 1Tb from the capacity side but at same time it’s twice expensive. The question of your budget...
por
wow that's really awesome, since its a 600$ beast i think its really worth it to put in a ssd and since its actual sata III cable now its not a waste of money
por
@taurus330 would it be possible for you to time how long it takes to load fallout 4 to the menu and maybe also gta v to story mode or online? that would really give everyone a good point of view because there's alot of loading time test done already with the one x hdd thanks
por
Fallout 4 from the xbox main menu to the game main menu - 17 secs.
Loading of the saved game - 18 secs.
Teleporting from one point to another - 12 secs.
Don't have GTA V.
por
Mostrar 4 comentarios más
We can confirm the below:
Xbox One X ships with a standard laptop HDD. Regular laptop SATA SSD should work. Don’t know if the connector is 3.0 or 6.0 Gbps though.
It will not work by itself because Xbox One is not designed to let user swap HDD. Manual repartitioning and statically assigning Volume IDs required.
After that manual download of system files are required. Then the machine should recover itself. Check HDD swap tutorials on YouTube.
Calificación 1
Comentarios:
I was wondering if you can go larger then a 2TB SSD
por
No.
1.8Tb is a limit for internal HDD/SSD in XboX One system.
por
Can I simply put my internal HDD from my recently broken Xbox X into a brand new Xbox X without having to format or hack the HDD? Or is each internal HDD specifically locked to the hardware/console in which it was manufactured?
Btw, I'm not concerned about voiding my warranty on the new Xbox X by opening it.
por
@topaznutsack You can swap HDDs between consoles, as GUIDs are the same across all XB1X's.
FTC ruled April 11 it's illegal to enforce a consumer opening their electronics voids the OEM warranty, per the Magnuson-Moss Warranty Act (15USC50 & 16CFR700) [FTC]
FTC ruled "warranty void" stickers on electronics are illegal & unenforceable, and it's illegal for OEMs to state: "The use of [company name] parts is required to keep your . . . manufacturer’s warranties & any extended warranties intact."
por
So it would work? Also, the parts that broke in my Xbox One X is are the controller sync module and a small plastic pair of parts that connect the board to the thin front rf board (behind power button). Doris anyone know if/where I can get those parts?
por
did I need to do anything to the hard drive like firmware update or will the xbox one x just prepare the Hard drive once its formatted
Calificación 0
You can easily clone it with a Mac or Linux machine. You will first need to identify the disk then run a command like
sudo dd if=/dev/disk1 of=/dev/disk2
disk1 is the Original Drive
disk2 is the new SSD
there are additional parameters to the command DD and you may want to read about it by typing
man dd
The dd command doesn't display any progress so just wait. It will copy all data (including the empty portion of the drive). If you accidentally used of=/dev/ (original Xbox drive) then your data is irrecoverable. So make sure you used the correct disk handles
If you're using Windows, you can download a virtual machine for Linux and make sure both drives are connected to the linux box (they may not mount because of NTFS partitions)
Calificación 0
Comentarios:
DD doesn't work. The reason being is that it is a sector by sector clone. It will not resize the disk. If he clones a 500gb hard drive to a 1tb hard drive, his xbox will still think he has a 1tb hard drive because the partition doesn't get expanded.
por
You really don't want to utilize dd for a few reasons:
1. dd doesn't care what information is on a storage medium, as it copies bit by bit... because of this, attempting to transfer data from a non-out of the box console will likely take several days.
2. Windows natively has all the tools required to not only create partition images [dism /capture-image /?], apply captured images [dism /apply-image /?], but also allows one to maintain a backup copy of their partitions as WIMs.
por
Don't need Linux or Mac or virtual machines: look for Win32 Disk Imager (is free) on Windows, equivalent of dd.
por
Can we use a m.2 2tb drive? & is there a connector PCB that will go to the SATA port? And will that have better speeds than the SSD?
Calificación 0
Comentarios:
You'd have to use a M.2 to SATA converter board, but yes, it's possible.
Both M.2 PCIe SSDs and 2.5" SSDs will have roughly the same speeds [dependent on drive specs], as both will still be using a SATA 3 interface, of which limits speed to a max of ~550MB/s
por
Is the procces of replacing the HDD for an SSD different on the Scorpio edition, since it specifically mentioned in the 2nd post?
Calificación 0
Comentarios:
There is no difference.
por
Añadir tu respuesta
mitchell de waard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 58
Últimos 7 Días: 363
Últimos 30 Días: 1,821
Todo El Tiempo: 28,932
