Saltar al contenido principal
Released by Samsung in March 2016. Model SM-G930.
Preguntas 419 Ver todo
My phone won't turn on it keeps vibrating
I have a S7 and it won't turn on, the screen is blank I thought its just needs to be recharge, so then I put my connector its just starts vibrating by itself every 5 sec. I tried to power it on while on charge then it vibrates very long about 10 sec what could be the problem? I need help please ...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 67
6 comentarios
Thank you it was very helpful for my phone and I happy it worked thank you for you for helping
- de
who helped you what message
- de
I have Samsung s8 I haven't charge it in months. I plug it in and it wont turn on all I can hear is the vibrate of the phone. Is there any way I can fix that problem to turn on??
- de
my samsung j4 wont charge nor turns on it just vibrates and nothing else please help
- de
Hi, I hasn't charged my samsung mbile from months ago. right from an 1 hour, it is vibrating. Any solution Please??
- de
Mostrar 1 comentario más
Agregar un comentario
13 Respuestas
Respuesta Más Útil
Let the phone charge a few minutes then unplug it and press the volume down and power button at the same time until it boots up. I've had the same problem with my Galaxy Ace 4.
Fue útil esta respuesta?
Puntuación 8
9 comentarios:
Thank you so much. You just saved my life.
- de
OMG! thank you thank you thank you so muchhhh!!!! you just saved my life. I thought it won't be able to open again but then booooom! thank youuu!
- de
HELLO SO what if i dont have a power button
- de
like its broken
- de
I had the same scenario going on but all I did was change the charging adapter and the vibration stopped. It’s not the fast charger anymore but it works and it’s not the port on my phone or the wire that was the problem.
- de
Mostrar 4 comentarios más
I had this prob w my Note4. Came close to junking it. I did everything from putting it in the freezer for 20 mins, to setting it in the sun, to doing nothing for a few days, to trying different cables, to doing a recovery boot, to safe mode, to power button hits, to buying a new battery.
I am NOT a tech whiz. I understand little about my phone. I’m a woman in my mid-50s. But I'm a stubborn problem solver and look for online fixes to probs w electronics.
Here's what's working for me—though it's not a perfect solution. I'm continuing to pursue a complete fix.
My phone was completely dead and wouldn't take a charge. Just vibrated and buzzed. Just before that, it randomly shut off and on. It was really rainy for a few days, and I was outside w my phone. That prob was an initial problem. But even 2 weeks after the rain incidents, the phone wouldn't work. I was really quite hopeless about it reviving.
My #1 suggestion is to try to charge up the phone via a computer and USB cable. The low battery (around 15%) is problematic. I found great hope in knowing that if all else failed, I cld charge via a computer.
Once the phone took that charge, I did a factory reset. It now will charge from AC, but seems very finicky about which charger and charging cord it will work with. So far, I haven’t been able to get it to charge w a car charger. Still working on that.
I'm also charging up the other 2 batteries I have for this phone in case I get caught w a really low battery again and no place to charge. Work in progress . . .
Hope this helps someone.
Puntuación 5
1 comentario:
so my phoene not working right and i read some of these messages and now we finna see the results in a lil bit tho.... we got to let it charge for a few min.....it's on 2 wait until 100 okay ...........so wait until like 2 hours okay then i be back 4 part 2
- de
Since there doesn’t appear to be an answer here, I will tell you (and anyone who comes here looking for a solution) what worked for me.
If the phone is buzzing like this when you are charging it using the physical charging port it is usually caused by something interfering with the charging port. Simply try blowing into the port to remove any dust or other stuff and try charging again.
If that doesn’t work, try using a wireless charger to charge it. If it doesn’t work or if your phone doesn’t support wireless charging, I can’t help you there but from what I saw there might be an “issue with the display” so look that up on Google or something.
Puntuación 2
So I just had the same issue with my S9+. It is severely cracked and damaged and is an extra phone, but has been working for me for odds and ends. Then I hadn't used it in a while and I thought the phone was dead so I tried to charge and it wouldn't turn on and would have a short steady buzz that would turn into and long continuous buzz. I tried everything that this website suggested and it was all a miss until I tried this…
While the phone is plugged in, wait til it turns into the long continuous buzz. Then press and hold the power, volume down, and Bixby button just below the volume down. A screen popped up that gave me a few option like power down, factory reset, restart, and one other option that I can't remember. I chose restart which was the first option. Then my phone went through the startup process. My phone is still dead so I'm not 100% sure yet if it was an absolute fix and won't know til its charged but so far so good!
Puntuación 1
1 comentario:
I seems to have worked for me. Well at least more than the others. It got me to the starting screen but hasnt moved from there.
- de
I quick reboted my phone by holding power-button and decrease volume and the phone turned on. So now the phone gave me an accual reson for refusing to charge and vibrating while showing the error sighn wjere it should show the power percentege and a blue drip over the non-charging icon. It said theat moisture was detected and to disconect de charger until it dries out.
Hope this helps.
Puntuación 0
I have a S9+ that I haven't charged in awhile, it did the same when i tried to charge it. O remembered when I first got the phone it froze I ended up going to store and they did a reset, I did that now and it is charging now. So at the same time push volume down,the button under the volume and the power button hold all them down does a factory reset follow the promts. I hope this
Puntuación 0
1 comentario:
Oh one more thing have to hold the 3 buttons all ar same time for 30 seconds the screen will go to start up screen then hold power button like to start your phone . Good luck
- de
Can it be done with Samsung Galaxy A as having same problems
Puntuación 0
could it be done on j7 pro samsung?
Puntuación 0
1 comentario:
I have a J7. For the past 3-4 weeks it shuts off, freezes, or the flash light turns on while continuously vibrating.
I have to do a force restart (several times a day). To do this I hold down the power button (on the right side) and the volume down button at the same time. Hold them down for 5-10 seconds. Then I select normal boot. If it is on a different selection, use the volume buttons to move through the list and the home button (on the face of the phone) to select.
My plan is to back up my phone next week and to a factory reboot.
- de
your battery could be fried
Puntuación 0
Related to the “Moisture detected” situation, I discovered that some gunk had built up inside the charging port. So I used the pin thing that comes with the phone to scrape out some of the gunk, and now my phone is back to normal.
Puntuación 0
sadly, this aint an answer but i’d like to say.. i tried every thing people have said and my phone still wont turn on and it keeps vibrating, what should i do?
Puntuación 0
1 comentario:
Have you tried a force reboot/reset?
- hold down the power key (right side of phone) and the volume down button (left side) at the same time. Hold them down together until your phone gives you a tiny menu. Select Normal start.
Delete as many apps as possible. These phones don't do well with a lot of apps.
- de
my samsung a20s not open it just Viavrating steel not open
Puntuación 0
2 comentarios:
Try holding down the power button and the volume down button at the same time. Hold them both down for like a minute. It should give you a menu to reboot. Move through the menu to the normal boot with the volume buttons. And select with the power button.
- de
does that work on oppo a5s?
- de
can you please help me my samsung a52 I accidental drop it on the floor then, won't open and continue vibrating with warning sounds what should i do.
Puntuación 0
Añadir tu respuesta
Kian Asuncion Basilio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 53
Ultimos 7 días: 383
Ultimos 30 días: 1,608
Todo El Tiempo: 92,475
