Why did the speedometer gauge stop working?
I replaced speed sensors and instrument cluster but gauge on speedometer doesn't move neither does the numbers on odometer.
Es esta una buena pregunta?
It is possible the electrical wire connecting the two is broken or grounding. You can use a multimeter to find out if there is a break in the wire.
Fue útil esta respuesta?
Check for an open in the wire harness to the speed sensor form the PCM.
At the PCM connector C2 (middle one) Terminal 25 Dark Blue/Black and Terminal 28 Light Green/Black.
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 288
