Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4256 Ver todo
How to tell Screens & LCD Assemblies apart?
I always label each screen when it arrives. Another tech gave me a bunch of unlabeled & unused screen & LCD Assemblies because he no longer has time to do the repairs. They are in plastic and I cannot manage to differentiate between them. I am trying to decide if I should just toss them or how I can confidently tell which screen & LCD assembly is which. I know they are all iPhone 6 assemblies. They were ordered from Amazon, so the only packaging is the plastic, and there are no labels to say which is which.
I know from the assemblies (and repairs I have done) some phones have a sideways screw near the camera assembly, some phones have two parallel in line ribbons, some have one ribbon going left to right and one (smaller one) going up and down, some have 3 ribbons, and one assembly (with camera and home button) has 4 ribbons. Some phones seem to have the home button ribbon built into the LCD and some seem to keep it attached to the back plate. These are the obvious differences I can see.
What specific physical differences are there between the screen assemblies (without home buttons, back plates, and the camera ribbon assemblies) are there between the iPhone 6, 6S, 6S +, and 6+?
Update (11/05/2017)
OK, so looking at 5 of them all of which are the same size and I believe are therefore Plus displays.
First, the known Display - in the box is a 6S Plus display (Still in the box and purchased for a replacement tomorrow).
I therefore believe this is a 6S Plus Display as well (Note that the cable configuration is similar and it does NOT have the sideways screw).
This would make these three displays 6 Plus Displays, Note that they do have the sideways screw and similar cable configurations).
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
The screen assemblies are pretty easy to differentiate. The main difference between the 6 and 6S series is the inclusion of the Force Touch IC (embedded in the backlight shield) and the Touch IC (on the Flex) on the iPhone 6S assemblies. The iPhone 6 assemblies do not have these IC's. As for the 6Plus and 6S Plus, the same applies.
Take a look at the pictures here and here.
Imagen iPhone 6 LCD Screen and Digitizer
Producto
$0
Imagen iPhone 6s LCD Screen and Digitizer
Producto
$0
Fue útil esta respuesta?
Calificación 2
Comentarios:
Nope, you have them reversed :>). The top 2 are 6 displays, and the bottom 3 are 6S. As for regular vs plus, just measure them. Check the images I linked in my answer and you'll see.
por
Añadir tu respuesta
Wissmiller Services estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 20
Todo El Tiempo: 183
