Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1525 Ver todo
iPhone not powering on after screen replacement, but original works?
I recently bought an iPhone 6 plus with a smashed screen on ebay, hoping to repair it with a replacement screen. I have done a few iphone screens before, and followed the same procedure, however when I turned on the phone I get no response, not recognised by itunes, no sound or vibration, nothing. I then replaced the smashed screen, as this one I could see when the phone was on but the touch did not work. The phone still powered on with the smashed screen on, so I hadn't damaged anything! I thought then the replacement screen must be faulty so I bought another one, but have the same issue. The phone was already on ios11 when I recieved it, and I have heard the update has caused some issues with replacement screens but was fixed in ios11.0.3 so updated via itunes, with the original smashed screen on, however both screens still do not work! Does anyone have any ideas?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The issues with iOS 11 and aftermarket screens mainly affects the iPhone 6S series.
Where did you purchase your replacement screens? Where they both from the same supplier? Low quality screens can be problematic and if you bought two from the same place, they could be part of a bad batch. Low-cost screens from eBay/Amazon tend to have the most problems.
It's clear that the phone (logic board) works and it's not a connector problem...that pretty much only leaves the replacement screen as the problem.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
rory highnam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 56
