Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1263 Ver todo
Replaced charging port; Replaced battery; worked 5 days then dead
Original problem - battery was dead and would not charge. The charging port was corroded so I replaced it and the battery would not charge. I replaced the battery, discharged new battery to 10% the charged to 100%. Worked fine for five days and now the battery is dead again and will not charge.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
It may be the charging ic if the battery drained and went flat then wouldn't charge.
If it is the charging ic then it has to be replaced by someone that does microsoldering.
Fue útil esta respuesta?
Calificación 2
Comentarios:
That was what I was afraid of because I can't get it soldered and the replacement is about $300.00. Thank you.
por
Añadir tu respuesta
Douglas Trout estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 40
