after overheating car I have full power but motor won't turn over
My 2000 Honda CR-V overheated now I get full power but the motor won't turn over it does make a clicking sound the battery is fully charged
Es esta una buena pregunta?
@paulbags it is possible that your engine has seized. Remove the plugs and see if you can turn the engine over with the help of a proper size socket and breaker bar. Don't use your starter for this.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 579
1 comentario
Thank you exactly right I pulled out the spark plugs one cylinder had clear sighs of having had water in it the motor was seized I filled all for cylinders with oil and left it for two days got my spanner and bar and managed to turn the motor over after half an hour a bit of wd40 it become that easy to turn I cranked it over with the starter motor a bit of petrol in the cylinders to clean them out plugs back in hit the key and it started straight away a bit smokey for a while but now you couldn't tell running like a dream THANK YOU
- de Paul artufel
