Saltar al contenido principal
The Chevrolet Blazer (and its cousin, the GMC Jimmy) can refer to one of several SUV models produced by General Motors including the Chevrolet K5 Blazer, Chevrolet S-10 Blazer, Chevrolet TrailBlazer, Chevrolet Tahoe, and Chevrolet Blazer.
Preguntas 30 Ver todo
My e brake was stuck when I pulled on it the line broke and now I can
Only go in reverse? What do I do ?
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Michelle Tate so your emergency brake cable broke. You cannot move forward because your brakes are locked? what year and what model is your blazer?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Michelle if the ebrake is locked in the on position the only recourse is to remove the drums and repair the siezed cable . When im faced with this problem I find its best to cut of the cable where it goes into the drum and work the cable into the drum to free up the brake enough to get the old drum off . I have had a sever case were i ended up cutting the drum in half to get it apart . But usually a lot f work with a heavy hammer can do the trick. Expect to have to replace everything in the drum with any luck it will only be one side thats locked on . Hope this helps
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Michelle Tate estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 484
