CD door won't open
'CD door
The door to the CD will not open.
What can I do to open it? When I press the button, the display says 'open,' but it will not.
Es esta una buena pregunta?
I presume this is the kind of CD drive with a tray which comes out when you press Eject and that you've tried inserting a straightened out paper clip into the hole in the front panel. I've seen this fault a few times. You need to remove the complete CD drive from the unit and open it up if it's inside a metal case.
I've described how to deal with this fault in the Restart Wiki.
Fue útil esta respuesta?
I would stick a paper clip in it but where?
Take a butter knife and GENTLY slide under the CD tray, on the left until you feel the catch release
Pamela Fowler, Thank you! This worked!!!
Ultimas 24 horas: 5
Ultimos 7 días: 22
Ultimos 30 días: 127
Todo El Tiempo: 8,260
1 comentario
Do you hear anything when you press open?
- de George A.
