Android-based media tablet by Amazon with 7" multi-touch color display. Repair requires only screwdrivers and prying tools.
Preguntas 193 Ver todo
My charger portal seems to be broken
Hi it looks as if something has broken off of my charging portal can I get it fixed
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
@noem2015 disassemble your Kindle. Follow this guide. You should check the solder connections on the micro USB port. It is very likely that they have either come totally off the motherboard or that they have micro cracks. It might be possible to reuse the old connector and resolder it, or you may have to find a new connector. If you need a new one, you could check mouser.com or digikey.com for a micro USB that fits the dimensions of your Kindle. Check on here about how to fix this.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Sophie davies estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 40
