Replacing iSight/Bluetooth/Wifi (cable only)
I damaged the connector of my MBP's iSight/Bluetooth/Wifi cable when installing an SSD.
I've bought a replacement cable but as my iSight/Bluetooth/Wifi are working fine I'm wondering whether I actually need to remove the glass over the screen to replace this cable or whether it just connects somewhere before it goes up behind the screen?
(more info - I think I broke the ground pin off the connector because odd LEDs in my display are flickering, causing light & dark 'spots' along the bottom of my screen)
Es esta una buena pregunta?
8 comentarios
UPDATE: I've successfully replaced the iSight cable but my LCD screen is still showing dim/dark spots along the bottom, as if alternate LEDs in the backlight are out... is this possible? Any ideas why it would be??
- de Peanut Turner
I am in the same situation but more dramatic... My Bluetooth is not working anymore.
I just looked at the LCD replacement tutorial and I think the cable is separating in two at the bottom of the screen. One half is going into the Wifi/BT module, the other one is running along the screen to the camera on top.
Maybe there is a connector at the bottom of the screen where the cable from the logic board comes from is connected and an other connector for the camera cable to start going ?
If so it may be easy to just open the black cover at the bottom of the screen.
You say you have the replacement cable. Is it one piece from the board to the camera (with a split in two after the first third) or does it go strait to the wifi/BT module ?
PS : excuse my english, I'm french.
- de Ben Souverbie
Ok I found this other post and it looks like the only way is to remove the glass over the screen...
Why does my wifi not come up (the camera doesn't work either)?)
- de Ben Souverbie
Hi Ben, yes I managed to get a replacement cable, and yes unfortunately it is all in one piece - I haven't quite gathered the courage to try and perform this repair yet, although I have bought one of those suction cups needed to remove the glass! :-) I will hopefully try to repair soon......
- de Peanut Turner
From where did you buy the replacement cable?
- de rajib
Mostrar 3 comentarios más
