Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Preguntas 491 Ver todo
Early 2011; How do I replace the trackpad?
I have a MacBook Pro 17" Early 2011. The trackpad barely works and I would like to replace the trackpad, but don't see any manuals / steps on how to do it. Understand that the actual part is about $60. Need help!!!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Check the battery for swelling first. 90% of the time it is the battery and not the trackpad giving you the problem.
UPDATE
Replacing the trackpad is very simple and essentially the same on all models of this era.
This guide, even if it is for the 13" should walk you right through it.
MacBook Pro 15" Unibody Mid 2012 Trackpad Replacement
Fue útil esta respuesta?
Calificación 3
Comentarios:
The battery is fine; no swelling.
por
Mayer ... thanks for the manual!!! I'm going to give it a try after I order the trackpad off of Amazon. I'll let you know if I'm "successful" or will need to buy another MBP. Appreciate your help!
por
Añadir tu respuesta
Maputo59 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 80
