iPhone 6 is dead ,no image, recovery mode on pc.
I have the problem is a died except that it is recognized by the computer in recovery the screen does not react and the logic card in question of temperature to normal without overheating without apparent damages without historics of great falls or damages caused by water I am investigating before moving evasively in it.
the logic board reacts normally when connected to the computer about 20 degrees and although it has no reaction on the screen, I do not have a test device to test the screen, I think it is functional.
I will be grateful for some help
update ...
A restauração foi um sucesso, no entanto, ainda não dá uma imagem. A exibição está intacta. A placa lógica há um pino com má deformação. Eu não acho que essa seja a causa do distúrbio na exibição.
Pretendo testar a exibição em outro dispositivo o mais rápido possível.
Como eu tentei deixar o intender na postagem ", acredito que o problema está em hadwareer it still does not give an image. The display is steplessly intact. the logic board there is a pin with bad deformation.
I do not think this is the cause of the disturbance in the display.
I intend to test the display on another device as soon as possible.
as I tried to leave the intender in the post ', I believe that the problem is in hadware
Es esta una buena pregunta?
