Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Preguntas 922 Ver todo
Audio out dead (low volume + static) after battery replacement
Hello !
I tried to replace the battery of my iPod classic (160gb, thin). I broke the cable of the hold button, but everything else seems to be alright. When I listen to musics, the volume is very low and there's a lot of static, which makes the iPod impossible to use.
Do you think replacing the hold button (and the audio jack at the same time) would fix the problem, or I definitely broke the iPod ?
Thanks for your help !
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
@perdouille replace the cable. This sounds like you are shortening the audio IC. Your headphone jack and hold button share the cable. Here is the guide for it iPod Classic Headphone Jack & Hold Switch Replacement and the part is available right here iPod Classic (Thick) Headphone Jack & Hold Switch
Imagen iPod Classic (Thick) Headphone Jack & Hold Switch
Producto
$29.99
Fue útil esta respuesta?
Calificación 1
Comentarios:
I bought a replacement, let's see if it works ! Thanks for your help !
por
It looks like it's working ! Thanks a lot !
por
Añadir tu respuesta
Lou estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 49
