Craftsman Lawn Tractor: How do I replace the Transaxle Variation Belt?
My Craftsman 42" Lawn Tractor (Model # 917.203901) will not move forward or backward, and the Drive Belt is fine.
I have found that the Transaxle Variation Belt has shredded and come off in pieces.
My novice understanding is that this belt is turned by the transaxle to set the speed/gear commanded by the foot pedal. This belt then turns the rear drive pulley that makes the mower move at the commanded speed/direction.
Or maybe vice versa, but it obviously is the belt that allows the mower to move at different speeds/gears.
There is all kinds of info, videos, etc on replacing the Drive Belt, but I can't find a single source for replacing the Transaxle Variation Belt.
Not even the Sears helpline seems to be able to provide any info. They are sending me a new belt, but they did not have any info on how to replace it.
Thanks!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
@vharbuck what model is your Craftsman? I am a bit confused by this. Craftsman uses a lot of Hydrogear tranaxles and on those The input shaft and pump cylinder block are turned in one direction only by the engine/drive belt/pulley combination. I do not see any other belt. Can you post some images of where this belt sits and what it drives? Use this guide Adding images to an existing question for that
por
@oldturkey03 , I added photos... it's item 2 on the Tranaxle diagram. thanks.
por
por
por
Amazingly, there is absolutely nothing online about replacing this belt, but there are lots of videos about replacing the main drive belt.
It seems this would be covered under warranty since apparently it is a rare failure item, but Sears said it was not covered.
por
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
@vharbuck notification just popped up :-). Bear with me and I am going to check to see what I can find out.,
Now I see what it does. Same as the old Skidoo engines (or DAF:-)
This mower is sold by Sears but actual built by Husqvarna so lets see whose axles they are using.
Update (10/19/2017)
Okay, so it uses a General Transmission RS800P transaxle.
- Remove cutting deck (see owner manual)
- Lift up the rear of the tractor, then remove both rear wheels.
- Disconnect the variation rod (1).
- Disconnect the switch (4).
- Disconnect the bypass rod (2).
- Disconnect the brake spring (3).
- Activate and lock the parking brake, to slacken the belt , and remove it from the main pulley (5).
- Remove the mounting bolts, to separate the transmission from the frame.
We recommend to keep 2 bolts partially unscrewed, to prevent the transmission from falling.
- Lower the rear of the tractor until the transmission lightly touches the ground, then remove the 2 last bolts.
- Lift up the rear of the tractor to release the transmission.
Update (10/19/2017)
@vharbuck this should help you out to at least get to the drive/belt.
Fue útil esta respuesta?
Calificación 2
Comentarios:
@oldturkey03 , Wow! That might be beyond my skill set, at least timewise, but I’ll take a closer look to see. Thanks so much for the info. I have some more mechanically-inclined friends who may be able to help me get this done..
por
Añadir tu respuesta
Henry V Harbuck estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 18
Últimos 7 Días: 95
Últimos 30 Días: 378
Todo El Tiempo: 3,199
