Saltar al contenido principal
A1418 / EMC 2833 / Finales de 2015 / 3.1 GHz Core i5 o Procesador Core i7 de 3.3GHz. Lanzado el 13 de octubre de 2015.
Preguntas 96 Ver todo
SSD Socket in HDD Model
I recently purchased a 21.5" 2015 4K Retina iMac from an old friend. It only came equipped with the standard 1 TB HDD but I'd like to replace it for a SSD. I'm wondering if I will find that there is still the Apple Socket for the OEM SSD's on the back of the logic board, so that I could add one of those (if I can find one) instead of adding a 2.5" SATA SSD?
Short question - is the SSD socket on the back of the logic board still present (just empty) on an iMac that only came with a spinning hard drive?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Your systems specs: iMac 21.5" i5" 1.6 GHz (Late 2015) as well as the others in iMac 21.5" 2015 (iMac16,2) line.
From EveryMac:
  • This model has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector (PCIe 2.0 x4 NVMexpress interface), but this connector is not present if the system only is configured with a hard drive at the time of purchase.
So sadly no, you'll need to swap out the 2.5" HD for a SSD or what I would recommend is think about getting a ThunderBolt2 external SSD RAID drive and make that your boot drive.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Many thanks for the answer! Not what I was hoping - but SATA will work!
- de
Añadir tu respuesta
gregory estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 159
