A line of external hard drives by Western Digital, styled after hardbound books. Available in various editions from Essential, to Premium to World Edition.
Preguntas 21 Ver todo
My Book won't power up
My MyBook 3T Drive, less than 1 yr old, only used for Time Machine backups, refuses to power up now. Have no idea why; I haven't even backedup that many times so it's got plenty of space.
I've tried different outlets, also subbed in the power cable from my older MyBook Studio, all to no avail! This is especially maddening since I have many externals, one from 2006 even, that I no longer use but still powers up! makes me think newer is less reliable - !! This really blows!
so if I tear it down, what am I looking for?
is there a way to access it w/o a power source?
fyi, it's barely 1 yr old - bought it in Aug 2016
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Wait, don't tear it down, it could still be under warranty...
por
yeah but that means replacement, right? there are backups on there, I don't want to give away all my data carte blanche -
por
anyway, by tear it down I mostly meant to access the drive via a computer rather than direct power
por
Agregar un comentario
1 Respuesta
Solución Elegida
*update*
Talked to WD on the phone to verify they would replace the drive but not remove the data or send the old drive back. I said I didn't care about the warranty, just the data, so he said just to remove the drive and buy a SATA cable to reconnect and obtain the data that way.
WD also said take the bare-bones drive in and show to a tek to buy the propert SATA. I went to MicroCenter and the clerk in the Build Your Own dept showed me a case with a power cable and a new power board that would just plug into my hard drive (once I removed my power board) and that should do me. $19.99. I just now finished - took all of 10 mins or less.
Was a snap. Just ran a diagnostic on the hard drive as yeah, I was concerned. Everything is fine. Apparently the power board (I don't know what the tek term is but it's the board where the power cord would connect) was bad in the old one. Very happy camper now !!
Fue útil esta respuesta?
Calificación 3
Comentarios:
Hey , I'm facing the same issue. Can you help me build the board which you built ?
por
Añadir tu respuesta
sunnryze estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 10
Últimos 7 Días: 60
Últimos 30 Días: 355
Todo El Tiempo: 3,257
