Loud fan, hot top left edge
I have an iMac 21.5" from mid 2011 that I don't quite know what to do with.
On startup, and initial boot, it's fine. After a while though, a loud fan-like noise occurs. Given enough time, the top-left of the iMac near the ventilation strip gets hot to the touch. It seems to be coming from close to the top of the iMac, so I thought it was the hard drive. I replaced it, thinking that might be the solution. (it wasn't but it can now run MacOS Sierra reasonably well, so I'm pleased with that)
I took a closer look, hoping to diagnose it further. I installed iStat on the iMac, and it showed that all internal temperatures were hovering between 97-148 degreed Fahrenheit. At this point, the fan(s) was (were) running quite loudly.
I poked around a bit on the interwebs, and came up with two possible solutions:
-Add a Digital Thermal Sensor
-Replace the CPU fan
Just looking for some feedback as to which course of action might be preferable. If more info is needed, let me know.
Thanks in advance.
Es esta una buena pregunta?
