Saltar al contenido principal
A1418 / EMC 3069 / 2017 / Procesador i5 de cuatro núcleos a 3.0 GHz, 3.4 GHz o i7 a 3.6 GHz de cuatro núcleos. Lanzado el 8 de junio de 2017.
Preguntas 175 Ver todo
What ram should I buy for iMac 21.5 4k 2017?
Hello everyone, I have a iMac and I want to upgrade ram for it. I have some questions so I hope I can find the answers here.
Does iMac 27 use the same kind of ram with iMac 21.5? Because I can easily find a kit ram to upgrade for iMac 27 but nothing for Imac 21.5.
Thank you all.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
First keep in mind opening your system will void your AppleCare warranty. Apple is being more aggressive on withholding warranty repairs if the system appears to have been opened.
So make sure you use the correct tools and don't leave any tool markings. Opening the newer 'Thin Series' are a bear! If you don't use the correct tools and technique in opening your system you can damage the display assemble which would be a very expensive Opps!
Here is the IFIXIT guide on how to get to the RAM: iMac Intel 21.5" Retina 4K Display (2017) RAM Replacement and IFIXIT makes a nice upgrade kit with everything you need! Here's the kit: iMac Intel 21.5" Mid 2017 Memory Maxxer RAM Upgrade Kit. There kit will push your system to the max of 32 GB! If you don't need that much you'll need DDR4 PC4-19200 2400 MHz SO-DIMM's
Imagen de iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) Memory Maxxer RAM Upgrade Kit
Producto
$189.99
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
JasonTran estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 982
