Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Screen split and half is stuck in phone.
I removed the screen, or tried to, so I could replace it. When I pulled it up with the suction cup, it split into 2. Almost like it peeled apart. The clips on the side all broke off. Now the rest of the display is stuck in the phone and I can’t figure out how to get it out. It’s almost like it’s glued in.
Help please!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Take a look at the last picture of Step 43 of this guide. It will show you how the screen is assembled. It sounds like the digitizer separated from the plastic frame. Or perhaps the plastic frame separated from the metal clips. Either way, you they are only held in by clips along the side of the housing. You should be able to pry this out. Just be careful not to damage anything else, especially the logic board.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Shara Nelson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,074
