Saltar al contenido principal
La Kenmore 110 Series es una lavadora para el hogar de fácil uso creada por Kenmore.
Preguntas 496 Ver todo
Does not complete final cycle.
Does not complete the last cycle. Says lid lock is on but the lid is not locked and you can open. You have to unplug the machine and the plug it in and set it to the last cycle to complete. after a while smells like something burning.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
@eficken it is a good indication that when it says the lid lock is on but it isn't that this is where your trouble is. I'd check it out first. Use a multimeter to see if it has power and continuity if closed. There may also be some wire damage since you say you've noticed some "smells like something burning."
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
eric estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 282
