A high-end gaming laptop from Acer. Features a 17.3" display, dedicated GPU, and a modular bay for either an optical drive or cooling module.
Preguntas 4 Ver todo
How to disassemble lcd screen? Acer Predator 17.3 (G9-793)
A few days ago, I bought an Acer Predator 17, turned it on, and noticed a problem with lcd display. So, as the laptop has no guaranty, I decided to disassemble the laptop and change the lcd screen with a new one. But couldn't find any screw on the lcd front bezel. How can I open it?
Thanks.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
I'm not familiar with that particular laptop, but laptop screens normally have any screws hidden under little sticky rubber pads or disks which you can pry off with a craft knife or just a small flat blade screwdriver. But often there are no screws and you simply insert a spudger or jimmy in the crack between the bezel and the back to release the clips. I've got one of these which is very effective: Jimmy
Imagen Jimmy
Producto
Jimmy
$7.99
Fue útil esta respuesta?
Calificación 2
Comentarios:
Thanks for your answer.
The bezel seems not having any screw hidden. I'm going to try the second solution and put the result back here.
por
I made a video that may help you out.
https://www.youtube.com/watch?v=4xZo06Gb...
Calificación 0
Añadir tu respuesta
erfan razi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 39
Todo El Tiempo: 511
