Saltar al contenido principal
Guías de reparación y solución de problemas para las laptops Acer Predator de 17,3", un grupo de computadoras para juegos de gama alta de Acer. Estas laptops cuentan con una pantalla de 17,3", GPU dedicada y una bahía modular para una unidad óptica o un módulo de enfriamiento.
Preguntas 16 Ver todo
How to disassemble lcd screen? Acer Predator 17.3 (G9-793)
A few days ago, I bought an Acer Predator 17, turned it on, and noticed a problem with lcd display. So, as the laptop has no guaranty, I decided to disassemble the laptop and change the lcd screen with a new one. But couldn't find any screw on the lcd front bezel. How can I open it?
Thanks.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
I'm not familiar with that particular laptop, but laptop screens normally have any screws hidden under little sticky rubber pads or disks which you can pry off with a craft knife or just a small flat blade screwdriver. But often there are no screws and you simply insert a spudger or jimmy in the crack between the bezel and the back to release the clips. I've got one of these which is very effective: Jimmy
Imagen de Jimmy
Producto
Jimmy
$7.95
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks for your answer.
The bezel seems not having any screw hidden. I'm going to try the second solution and put the result back here.
- de
I made a video that may help you out.
https://www.youtube.com/watch?v=4xZo06Gb...
Puntuación 1
Añadir tu respuesta
erfan razi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,178
