Saltar al contenido principal
A 2-in-1 laptop/tablet with full 360° folding capabilities. Contains a 2.00GHz i7-5500U processor and was released in 2015 with model number 80JH000WUS.
Preguntas 20 Ver todo
The fan won't turn off.
Hello,
the fan off my Lenovo Yoga 3 14 (80JH) is not turning off. When you start the Notebook the fan is turning on right away. I tried apps like "NoteBook FanControl" or "Speedfan" or "TPFanContol" all aren't working. They detect the fan at 112% working, but all tries to reduce the fan speed are failing.
I hope that someone can help me. Everything that I found on google couldn't help me.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Check the temperatures Speedfan is reporting. Are they on the high side? If the fan or air vents are partially blocked it may be that is running continually trying to move enough air to keep it cool. Loosen any matted dust behind the vents with a pin, then try and suck out the dust from both the air inlet and outlet. If that doesn't help, there's an iFixit guide Lenovo Yoga 3 14 Cooling Fan Replacement for replacing the fan, which is marked "Easy", which should allow you to bet better access. But you'll need to renew the heatsink paste.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Steven Zierfuss estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 27
Todo El Tiempo: 3,962
