Not showing up in wifi/ won't connect
My question is about the ProMark p70 drone and the wifi that is supposed to be built into the Drone. It connects to the actual controller but will not connect to my smart phone. Also when you look in the WiFi in your settings on your phone there doesn't show any WiFi device for the promark and I'm trying to find out if I can manually put it in or what I should do thank you for all your advice and answers.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
This is how you fix the problem:
On the phone's list of available wifi networks, tap and hold the one for the drone (mine appears as "P70-VR-1F5500") and then tap or keep pressing on tap "Modify Network". Then change the IP settings from DHCP to Static (under Advanced) and set the IP address to 192.168.1.1, Gateway to 192.168.0.1, Network prefix length to 24, DNS1 to 8.8.8.8, and DNS2 to 8.8.4.4 Then tap Save.
Then when you connect to it you'll get a notification/prompt telling you there's no internet and asking you if you want to stay connected -- tap Yes. There's also a box you can tap to let it know it doesn't have to ask you that every time you connect to the P70's network. Hopefully, that will work for you too...
05-10-2017 01:29 PMLike
0
Quick reply to this message
Zekir's Avatar
https://forums.androidcentral.com/showth...
#5
Zekir
129.168.0.1-1.0-fra 8.8.8.8.-8.8.4.4
por
How do you do it on a Galaxy S8 I've tried to connect and it states no internet available. Contacted support and they instructed me but it still does not work. Thinking bad sensor or something and I just purchased it 4/25/18 ugh
por
I'm confused on this one, in the question he stated " when you look in the WiFi in your settings on your phone there doesn't show any WiFi device for the promark" but you said to select the one for the drone but he has none listed...
At any rate, I'm having the same issue I don't see a listing for the Promark. I can connect my DJI and a DJI I was repairing just fine but I'm not getting a wifi signal from the Promark.
Thanks!
por
I had the same problem. took off the camera there are two white plug connections one of mine were unplugged I guess from landing over time it came unplugged. reconnected and now good to go.
por
Agregar un comentario
3 Respuestas
Solución Elegida
Yes it is a bad camera. The wifi signal comes from the inside of the camera and you can tell if it's working or not because it'll light up red inside. The only way to resolve the issue is one or two ways. First you could get another camera for the Drone that you have searching for it online and hopefully it would be fixed and that aspect. Secondly would be getting a new drone. Third you could also contact promark and they will help you tremendously I called because my battery and my GPS shadow drone was not working properly and they sent me another battery free of charge. Customer service was excellent and those batteries are about 50 bucks. So that's how I resolve the issue let me know if you have any other questions.
Fue útil esta respuesta?
Calificación 0
Comentarios:
I have a aurora foldable drone with the same problem. When I ordered it I had the camera upgraded. It worked wonderfully. Then out of the clear blue no WiFi.
por
I will forward you the info I found regarding this which I found on the Promark website. Did you download on your smartphone the Promark VR aerial photography app? Then
HOW TO CONNECT
1-Download the Promark VR app for iPhone or Android.
2-Power on the drone.
3-Open the WiFi settings on your phone and connect to “P70-VR” WiFi. Tip: you may need to reset your WiFi by turning it off and then back on again.
4-Once connected, open the Promark VR app and press “Play”
5- For VR streaming, click the “3D” button on the screen and place your phone into the Promark VR 3D Goggles (included in the P70-VR drone).
Shut down the drone and turn it back on if it is still does not show.
Hope it is helpful
Calificación 0
Comentarios:
I have done all of that and it still does not show up when I turn WiFi on. Is there a way to manually enter it in? As if you were adding a network?
por
Make sure you are in the range of your wifi connection. If you are trying to use it outside of your home network, you will need to set it up with your smartphone hot spot
por
Still no go. I have tried everything so far
por
I have tried all your suggestions and it still doesn't work
por
i have the same problem have you ever figured out how to connect
Calificación 0
Comentarios:
Billie Carpenter. Did you ever get your issue solved? And if so how? Thanks
por
Or has anyone else had the same problem as Billie and got it fixed?
por
Well I have found everything from bad cameras, broken wires, loose connectors and even broken female connector on the main board. I offer repairs. For Holy Stone HS100 and Shadow drone. Find repair service on eBay. Under: Holy Stone HS100 repair. Thanks and happy flying.
por
Añadir tu respuesta
Mathew williams estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 36
Últimos 7 Días: 213
Últimos 30 Días: 1,281
Todo El Tiempo: 6,634
