Saltar al contenido principal
Modelo de principios de 2011, A1278 /2.3 GHz i5 o 2.7 GHz con procesador i7.
Preguntas 759 Ver todo
Starts to boot and then shuts down shortly afterwards.
I recently replaced the fan on my MBP. I purchased a used fan from ifixit and swapped that because mine was REALLY noisy. Then about a week or so later this started to happen. The blue light on the front still blinks slowly, I have to force shutdown the machine, but the screen goes blank and nothing happens. No noises from holding buttons or anything.
I've tried all of the different resets I can find.
I've swapped in a different HDD.
I have no idea what else could be causing this.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
At this point I think you need to dig a bit deeper diagnostically. How about downloading these two apps:
Let see what they report. Paste the full main screens of both here for us to see.
Fue útil esta respuesta?
Puntuación 1
Comentarios:
I can't get it to stay running long enough to even get to a link to try and DL a program. :(
- de
Do you have a second Mac? If you do try connecting the two back to back in Target Disk Mode.
- de
Did you tried booting your Mac in Safe Mode?
Also, I will advise you to run Apple Hardware Test to determine a failing Mac component. I am not saying this 100% but the fan might be a problem. Might Be. You better run First Aid and AHT quickly. Keep us posted
Puntuación 0
Comentarios:
Simone - As Heath did try a fresh drive I don’t think booting up under Safe Mode will make much difference here as that would only offer a means to by-pass the loading of the extended driver set.
This sounds more like a hardware Vs software level issue.
- de
I agree with Dan, but I will give it a whirl anyway. I'll look up how to do them and give it a try tonight or tomorrow morning! Thanks for the next step in the ideas.
- de
Añadir tu respuesta
Heath estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 63
