Released 2016, January, identified by model number K430T. The type of display is IPS LCD capacitive touchscreen, 16M colors and a 13-megapixel camera.
Preguntas 30 Ver todo
My screen is cracked and chipped at bottom.
I have an lg k10. I was at work and dropped my phone on floor. The screen is cracked in different spots and chipped off at bottom corner. Can I just replace screen or what do I need to fix this problem?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Did you manage to replace the screen? I have similar problem :(
por
Yes, you can replace it, just follow the steps from the attached guides.
por
Agregar un comentario
2 Respuestas
Solución Elegida
Assuming it is just the screen assembly that needs to be replaced you should be able to find a replacement part online readily. I would normally recommend getting the part on the plastic frame if available. They are relatively inexpensive phones and screens look to be in the $40 range, this device might be more inexpensive to replace. If that is the route you take please recycle the device.
How to disassemble LG K10?
http://www.ebay.com/itm/New-For-USA-5-3-...
Fue útil esta respuesta?
Calificación 1
Respuesta Más Útil
If the display is ok and touch work fine you can replace the glass:
LG K10 Screen / glass Replacement
Calificación 2
Añadir tu respuesta
John lacy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 13
Últimos 30 Días: 26
Todo El Tiempo: 511
