No sound and powering off during calls after screen replacement
Hey everyone. I'm a tad freaking out right now...
I just replaced a screen for someone on the iPhone 7 plus and after doing that, there is no sound, and the phone is randomly rebooting. I checked all the connections and everything carefully and cannot find the problem.
I read a lot about the proximity sensor which everything is where it needs to be, but I have no clue and am freaking out! What should I try??
Es esta una buena pregunta?
9 comentarios
You placed the foam pads all back? I've read that having the pads damaged or taken off can cause some disturbance.
- de rooooooooossssssssseeeeeee
Yes, all the pads, double sided stuff, etc is all back on the new one. I've never had this happen....I'm literally shaking because I don't know what to tell this person.....they are going to be so mad to have a phone not working.
- de Matt Clark
The other thing is, I can hear sound from the phone when dialing a number, but when I call, there is no sound from the earpiece and then the phone reboots. It only reboots during calls...
- de Matt Clark
I believe I know the problem now....not for sure, but pretty sure......I think the flex cable spread apart where the sticky adhesive is near the lower left corner by the speaker. I didn't realize those were two separate cables stuck together. It makes sense to me because when I make a call the phone has no sound and reboots.......probably from those flat gold points not making the correct contact.
- de Matt Clark
Back again, sorry for the multiple posts........
So, the speaker and proximity sensors don't work, but the FF camera does. Do you think that helps determine the cable is the problem? Because I see that the proximity sensor/speaker terminal cable is separate from the cable that runs the camera to the logic board. I think when I was attempting to pull the cable out to transfer, I think I saw the gold contacts where the two cables a stuck together...
- de Matt Clark
Mostrar 4 comentarios más
