El smartphone Android de 5ª generación basado en Android de Samsung fue lanzado el 11 de abril de 2014. Las mejoras en el teléfono incluyen un escáner de huellas dactilares, cámara actualizada, pantalla más grande y resistencia al agua. Está disponible en cuatro colores diferentes; Negro, azul, blanco y cobre.
Preguntas 572 Ver todo
I can't access my files
Why can't I access my files it say something is turned off or not installed?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Can you be more specific about what you are trying to access
por
If I go to settings look in storage at explore nothing that I try to open will says it's turned off or not installed
por
What's turned off or not installed? We can't see what you can, so you'll need to give us as much information as possible.
por
@pccheese you're doin great, kid. Keep goin
por
@bmur98, do you see a "My Files" app in the phone? That can view your files and open your folders normally.
por
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
The only thing I can think of without seeing the device is that one of the main programs that utilizes whatever you're are attempting to open is disabled OR needs to be updated in the play store.
If you go to settings > applications> and look for the disabled and/or check for a software update, check the play store for application updates that may run the file you're attempting to open.
The only application I can think of for the S5 is either called Memo/Notes.
Fue útil esta respuesta?
Calificación 2
Comentarios:
It works now thanks
por
Glad to hear it!
por
Thanks iowloakkalsl
por
Añadir tu respuesta
Bill estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 40
Todo El Tiempo: 393
