Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4258 Ver todo
Changing my iPhone's motherboard
I've been using this iphone for quite a long time.Then it started too make problems.I brought it to a phone shop and they said i got to change my iphone's motherboard.What will happen if i change it?I really need help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Is your phone turning on?
If yes, do a backup of your data via iTunes or other backup software so you can restore it to the new motherboard
If no, you will lose all your data, this is the worst it can happen
The motherboard is the most important component in your iPhone so the most expensive
Fue útil esta respuesta?
Calificación 1
Comentarios:
Not now :( @soros So,if i change my motherboard all my data including my icloud will be lost?Its like a new iphone isn't?
por
It is rare that you come by a motherboard that "IS NOT" repairable. There are several Iphones I have received that the customer was told this (even though it's possible).
First, you should explain your issues in as much detail as possible to help experienced techs troubleshoot your problems.
Second, to replace your Logic Board, is replacing your phone (It is your phone). If it comes to that, you are better served finding a good deal on another phone and replace that way, then you could sell yours to offset the price.
Here on IFIXIT, you can find several experienced techs that can do a repair to most anything that offer mail in services and even no charge in some cases where it is not repairable. Of course you would probably prefer a local shop if available and you have done your homework to make sure they are reputable and good at what they do... but you are here now after going to a shop which tells me they are good and correct, it is not repairable...or they are not.
Please update your question to include all of your symptoms and history of the phone.
Best of luck!
Calificación 1
Añadir tu respuesta
Hazim Izz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 91
Todo El Tiempo: 408
