Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación y dispositivos para el teléfono inteligente Samsung Galaxy J5 2016, modelo SM-J510FN.
Detection of a component on motherboard
Hello.
Can anyone help me with detection of marked component from J5 Duos motherboard?
Looks like somethink wrong has happend..
https://ibb.co/edYuWv
Imagen
Thanks.
Update (09/11/2017)
Oh, thanks :-).
Phone was probably water damaged. I can see probably salt at two places on top of the borad. One image is from components around WiFi/BT and other image is different side of board - bellow front flash diode.
Imagen
https://ibb.co/fL3ota
Imagen
https://ibb.co/nAm8ta
So, phone is KO. Thanks.
Es esta una buena pregunta?
Puntuación 2
5 comentarios
I think you need to provide some background information. Is the phone water damaged? Does it turn on? Any serious drops?
- de
is that not a soldered shield over the top
- de
It is soldered. But what is under?
And can malfunction of this component be reason for no-functional phone?
- de
I need j5 (2016) Board
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@fbituco you'll find your BT/WiFi under that EMI shield. Could be a reason for non-functional if your BT or WiFi is not working. You'll have to give us a bit more information about what is not working on your phone.
Imagen
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Fbi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 1,944
