Won't charge, says This accessory may not be supported.
So here's the story; phone poorly taken apart, damaged chips, managed to get it to work but won't charge. One of the charging ics which I forget the name (9 pins, MOSFET, controls charging) was missing and had 3 ripped pads. Replaced that, now phones recognises charger bit says this accessory may not be supported, before would not recognise it at all. Not showing on pc at all. What should I replace next?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Hey Giga, I just noticed this question. If you haven't fixed this yet, please let me know which IC exactly you replaced so that I can help you out.
por
Agregar un comentario
3 Respuestas
Solución Elegida
@refectio i just used the board as a donor, used almost all the parts.
Fue útil esta respuesta?
Calificación 2
Cool, at least you put it to good use.
Calificación 2
1. Remove any debris from the charging port on the bottom of your device.
2. Restart your iOS device.
3. Try a different USB cable or charger.
4. Make sure that you have the latest version of iOS.
5. Contact Apple Support to set up service.
Calificación 0
Comentarios:
No, read the OPs original post. He took it apart and messed with the internals. It has nothing to do with a dirty charge port or bad cable/charger.
por
Añadir tu respuesta
Gigabit87898 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 39
Últimos 7 Días: 240
Últimos 30 Días: 1,319
Todo El Tiempo: 33,574
