How do I fix the brake lights. left side
How do I change the brake light on the left side of my truck
Es esta una buena pregunta?
If switching bulb to other side verifies bulb is Ok,
Or simply using test leads to truck battery -
Then you'll more than likely have fuse problem,
This panel might be in engine bay, if not inside cab.
The user manual will have location for fuse.
Note:
By Chance , was a trailer used recently?
I've seen this being the case many times,
The lead on trailer, or socket is damaged.
Blows the fuse.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 38
I don't know how to even take the light covering off
- de Joyce Makua
