Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Preguntas 217 Ver todo
Problem Charging, Tried SMC reboot and computer won't restart
Hi all,
The charger and light on my charger wouldn't work when plugged in so I turned it off, tried cleaning with condensed air, then turned back on. Didn't solve the issue. So I turned it off and tried an SMC reboot. After this, the computer will not restart. It was at about 22% battery when this happened. The charger was plugged in but not lit up when I did the reboot. I've tried several different ways to get the computer to reboot with no avail. I brought it in to campus IT and the guy thinks that the magsafe board needs replacing. What do you think?
As background, I had a small water spill that made the computer shut down several months ago. Apple was no help and told me the logic board was likely shot. I dried it, my partner disassembled it, saw no damage at all, and it restarted fine and has worked great since. I had the no charging or light on thing happen once before, prior to water, but that was remedied with a new charger. I don't want to buy a $70 part if that won't fix it. Would an apple authorized dealer be able to tell me if it was that part that was the issue?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Go to Apple if this is your situation https://www.youtube.com/watch?v=oftjwYml...
Otherwise google "your town & mac repair" and find an independent guy with a high review rating.
por
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The problem with water damaged electronics is that they may work for some time following the spill, but they could fail at any time following it -- even months later.
The MagSafe connector on the computer is a magnet (no pun intended) for dirt and grime, and especially tiny bits of metallic dust. I've seen more than a few laptops and chargers get fried because of this. Get yourself a small wad of poster putty (available at Staples, etc), press it into the MagSafe connector on your computer, then remove. The putty is non-conductive but will grab ahold of any dirt and metallic bits inside of your MagSafe connector. Continue doing this until the connector is clean, then wipe down the connector with a Q-Tip and a tiny bit of isopropyl alcohol to get the rest.
Now plug in A DIFFERENT charger and see if the computer charges and/or starts up.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Turns out my housemate has the same MacBook. We tried putting in my MagSafe board in his computer, and it works. If we use his MagSafe board in my Mac, it doesn't work. Therefor, the problem isn't the MagSafe board. Any idea? Would a third party be able to run diagnostics? The closest one is over an hour away
por
You removed the MagSafe connector from the equation by swapping them; did you also remove the charger from the equation by similarly swapping them? IOW, after you swapped the MagSafe connectors, did you continue to use YOUR charger on YOUR laptop, or did you try using your housemate's charger on your laptop (and your charger on your housemate's laptop)?
por
Before doing any of this, I tried multiple chargers on my computer and none worked. My charger did not work on his computer. His charger worked on his computer with my MagSafe board.
por
So basically I have determined that my charger isn't working, my magsafe board is working, my computer isn't working, and an SMC reboot caused some of the problem.
por
This is looking more like a hardware problem than a software problem. My next step would be to open up the bottom of the computer, disconnect the battery, put a bit of electrical tape over the connector (so it doesn't short anything), then plug in the AC adapter and see if it starts up. If it does, and the computer is behaving normally, then I'd probably do an SMC reset again. Once the computer comes back on from that, shut it down, plug in the battery, then try starting it again.
por
Mostrar 16 comentarios más
Añadir tu respuesta
Olivia P estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 16
Últimos 30 Días: 76
Todo El Tiempo: 1,025
