Saltar al contenido principal
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
Preguntas 99 Ver todo
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
Es esta una buena pregunta?
Puntuación 2
7 comentarios
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
- de
Different battery perhaps?
- de
Do I have to try with a different battery? Can it be a motherboard's problem ?
- de
Yeah, it could be either the mother board or the battery.
- de
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
- de
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Imagen de Asus ZenFone 2 Battery
Guía
Asus ZenFone 2 Battery Replacement
Dificultad:
Difícil
20 minutes
Imagen de Asus ZenFone 2 Motherboard
Guía
Asus ZenFone 2 Motherboard Replacement
Dificultad:
Moderado
15 minutes
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
- de
Añadir tu respuesta
Vincenzo Liguori estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 369
