Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Preguntas 1468 Ver todo
WiFi still greyed out after replacing antenna - Next steps?
So I replaced the WiFi diversity antenna after following the iFixit guide and it seemed to have gone well apart from the Wifi is still greyed out and the bluetooth still doesn't work. Please help, many thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I think you would need to contact a logic board repair service as the Bluetooth and Wi-Fi are on the same IC.
What country are you in?
Fue útil esta respuesta?
Calificación 2
Comentarios:
@gigabit87898 is most likely correct on board repair. Sounds like your wifi ic needs replaced or reballed. That has been the only reason I have found so far for greyed out wifi.
There are components surrounding WiFi ic to check as well, but either way would require Micro Soldering repair.
Check out this video: https://youtu.be/S91fukLKZcU
por
Thanks for the help @teetopp
por
@gigabit87898 @teetopp Think it's more than likely the wifi IC. I'm not specialist with these but do you think it'd be possible to replace this IC if I buy a new one as well as flux and a heat gun? Or is it a hard procedure that I should avoid
por
Personally, I would recommend a professional Micro Soldering Tech to do it. There are several things that could go wrong for a beginner from overheating, Tearing pads, knocking off other components, etc...
And... it may not be the Wifi IC, it could be one of the components on that circuit and a professional would be able to diagnose that before changing the IC.
You can look for local repair shops, call them and price it, or even look through the PRO ads here on Ifixit and find one that you could do a mail in repair :)
por
I agree with @teetopp. This is not the kind of thing you want to learn with when you still value your phone. If you want to do it yourself, buy a bunch of dead phones and practice, practice practice. Then try it again on a working phone before ever touching your own device.
por
Añadir tu respuesta
Matt Howard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 80
